Hi Y'all - Hope all is well. It's been a long time since I last posted here. I'm by no means mechanically adept and hope you don't find my question too stupid...
I own a 92 FXDC with stock dual calipers. Last year, I purchased a 16" ape hanger kit from Hill Country Custom Cycles, including the front master cylinder and braided lines. I had a hell of a time getting any pressure built up with the new set up. I spent a ridiculous amount of hours bleeding the system, and finally got the pressure through vigorous pumping, and mity-vac-ing, and reverse bleeding, Rode all last season with no problems at all.
Went to do a front pad change this winter. I didn't crack open any bleeder screws or open any lines at all. Just pushed the caliper pistons back in the bore slightly to remove the old pads. I lost all pressure in the system and can't get anything back. Tried all the bleeding tricks and techniques that worked last year, but can't get a damn thing. Never had a problem bleeding the front brakes prior to the new setup.
Can someone tell me if this might be a bad master cylinder and/or bad caliper? Is there any way to test the master cylinder? If I open a bleed screw and pump the lever, I don't even get any fluid coming out. Thanks very much in advance.
~Scott
~Scott
