My 2005 Dyna Wide Glide with EFI sat for a couple of years and has bad gas. It turns over but won't start. I am assuming that the fuel pump is shot as a minimum and will need to be replaced with the fuel filter and regulator. What else will likely need replacing: injectors, check valve, etc.?
Thanks,
George
fresh battery,,, drain and refill the fuel,, check fluids,, if engine oil is low,, with until it has run several minutes,, before topping off,,, sometimes oil zumps when sitting... and start it..
