1 - 14 of 14 Posts
The Anti-RUB
Anti-Sieze. You don't have to lather it on. A light coating will do it.
The Anti-RUB
Habanero Kid said:
coat the whole thing...
To be specific, put it around the entire shaft. Don't put it on the threads. :thumbsup:
pws said:
Curious to know why you would say this???
Many automotive & motorcycle OEM have specific admonishments for using lubricants/thread lockers/anti-seize on lug nuts or studs (e.g. GM & BMW).
The HD Service Manual directs a coating of anti-seize on the axle but does not state yea or nea on the threads. Me, I put anti-seize on the axle but not on the threads or nuts of the axle - obviously a lot of folks use it on the threads without any problem.
In any case, be sure to use it on the axle shaft.
In my mind it makes sense. On some large, high torque bolts, the torque itself will hold the nut on. A lube can actually help attain the proper torque too, allowing it to spin rather than get hung up and getting a false torque reading.
Head bolts can be the same way. I tiny amount on the threads and under the head of it.
Definatly NOT for every bolt though!
1 - 14 of 14 Posts
