There is an upgrade on Harleys site to upgrade the new Harmond Kardon stereo's in the 06 touring bikes, its suppose to fix some of the bugs in the stereo. It seems quite straight forward and easy to do, you just download the files and burn them to cd then install in the cd player on the bike.
1. With your radio in FM mode, eject any CD you may have in
the radio.
2. Turn the ignition key switch to OFF.
3. Press and hold any two soft keys and then turn the ignition key
switch to ACCESS.
4. Continue to press the soft keys until “Diag Test” is displayed in
the middle of the screen.
5. Press soft key 5, labeled “Update.
6. Insert the CD with your update files into the radio when
“Insert CD” is displayed on the radio screen (see Figure 3).
Do NOT close the CD player door.
The radio will automatically update the software. This process will take
about seven minutes. A message will inform you of the progress of the
update. The radio will power down and restart automatically twice
during the update. If the CD appears jammed or will not eject, shutturn
off the radio and, turn the ignition key switch off to OFF, and pull the
vehicle maxi-fuse, and wait five minutes before replacing the fuse for
five minutes. Try ejecting the CD again once power has been restored.
7. After the radio has restarted for the second time, press soft
key 6, labeled “TestExit” to return to normal radio mode.
8. Eject the CD from the radio.
FLHX vivid black
95" stage II
samson ovals
the radio.
switch to ACCESS.
FLHX vivid black
95" stage II
samson ovals
