This weekend going to install the Wild 1 mini apes on my 05 Fatboy. I am also just changing grips, using stock cables. For clutch side looks like i should just cut the grip, and everything should slip off...On throttle side, not sure what to do about brake resriv,,,,etc,,,,any help, I dont have any instructions, i bought the bars used,,,,,do i need to disconnect the brake line..etc....help
Don't take your brake lines apart. There is a pair of torx screws holding this whole assembly on the bars for the throttle side.
No Need to cut the grip it is not glued on. The brake line will look "shaky" with those bars IMO it goes from rubber to a black steel line just buy a braided line and do it right.
