Has anybody dynoed the bike yet?
would like to see some numbers myself on that cam.Have to think it would be bout the same down low as the 6, midrange a bit stronger? then the top end also a bit more than the 6.
You can run more compression with it i think, so it should do well. i don't think you will like the cam at 9.8 or 10. would think at least 10.5. maybe even around, 11.0 if you have better gas than i can get here.
There are people here that are qualified much better than i am to say what will work. but i feel 10.5 should be a good place to set it at, and the motor should be happy.
