Can anyone tell me why the brake lights are wired through the anti-dive valve on a '94 Ultra Classic? My brake lights stopped working and I traced the wires back to see if I could find the problem. When I unplugged the plug that connects to the anti-dive valve, I found that by putting power to the red wire with a yellow stripe, the brake lights came on. The other wire appears to be a ground. Doesn't make sense to me. If the valve is bad, could that cause the brake lights to not work? The service manual says that when you turn on the ignition, you should hear a faint click at the valve. I don't hear or feel anything at the valve. The brake light relay clicks when the brake pedal or lever is applied. Any idea what my problem might be?
Thanks!
Thanks!
