Cryptoboy said:
Cryptoboy,
I use a TH and I had one coated stainless steel and now I have the Black. I would NOT waste the $$$ for the shields. I didn't notice any difference in temp.
Bry
Cryptoboy said:Ok, so I'm pretty sure I'm going to get the Thunderheaders in the next few weeks. I was looking more at the black ceramic ones. Is there any benefit to buying heatshields for the ceramic pipes?
The only thing I've found is the shields block some of the heat felt by the rider. Is it that much hotter w/o the shields?
Yes, you will hear the radio just fine with a TH on an Ultra. The long muffler used on the touring TH makes for a nice mellow sound while cruising. It will bark when needed, but it sounds great.Gnarl78 said:I'm going to be getting an Ultra Classic soon:woohoo: Any thoughts on if I'll be able to hear the radio if I put THs on it?
A friend of mine had his TH done in black to go along with his blacked out theme of his '02 EG Standard. It looks great, and the coating has held up nicely over the years.Cryptoboy said:They'll be going on an 05 Electra Glide Standard, Gnarl. I had an 03 Lowrider, I put the Hard Krome Xcelerator pipes on it a few summers ago. The numbers were the same as the T-headers, and looks were far better (although the sound wasn't quite as good).
