I'd look into the N8s. My brother had them with Buell heads. It would make h.p. in the 90's.
Fourcats, you're the man.Fourcats said:If you are not running the S/E ignition {P/N 32734-98} for the 1200S, you are...lacking.
P/N 32734-98, Black, 6800 limiter. {They also had Red ones and some with a 7500 limit} The increased RPM is moot, as you gain LOTS way before that and won't be bumping the limiter.
Have your H-D dealer do a "parts locator search" {if they don't have one in stock} as they are discontinued. This will locate the dealer{s} who are likely to have the item. :chopper:
There's just one problem: finding one for a 1200S.95CDman said:If thats just another FIXED ignition map module(32734-98) that just raises the rev limiter a bit, I wouldnt waste the money on it. Better off geting an ignition module with an adjustable map and rev limiter. That way you can tailor the ignition to your engine combo properly. Those SE ignitions leave alot to be desired........
Now why would I do that?Fourcats said:Good deal...Don't get ARRESTED :duh?:
I ordered the ICM part # that Fourcats gave me; found it at a dealer in Valley Forge, PA. Supposed to increase RPM's to 6800. But how 'bout that coil? Would it be a benefit?jockeyshift said:Just saw this thread. Homarr, I too have a 1200S and I have the 7500 box in mine. I'll post the part number for that box tomorrow. I think it was in 98 or 99 they sold just the box by it self, later on they packaged the box and coil together. You had a choice of colors on the coil also.
Yep, the 6800 is fine and you should have no problems. I think 7500 is a little tall for the street and it seems to fall off up there anyway. I usually shift around 6500 if I'm on it strong. The coil is the same as the stock one. No benefit whatsoever. They are just different colors, thats it.Homarr said:I ordered the ICM part # that Fourcats gave me; found it at a dealer in Valley Forge, PA. Supposed to increase RPM's to 6800. But how 'bout that coil? Would it be a benefit?
I ordered the N4's from a local indy. (http://www.ledsledcustoms.com/)
Dude told me I should be fine w/ 6800 rpm max.
Thanks for the info!
I'll hold on to it all! I had to run back to work after the package was delivered. I imagine I'll have more questions to ask after I get home and read the installation instructions :dunno:jockeyshift said:Cool deal!! :thumbsup: Hang on to your old stuff. As you can see, it is getting harder and harder to find parts for the 1200S's
Step six was the only thing I wondered about when I skimmed over it. That's not anything like this, is it? http://www.v-twinforum.com/forums/showthread.php?t=69427jockeyshift said:Installation:
6 test engine for proper ignition system operation.
Will dojockeyshift said:7. Jockey's tip. Ride the snot out of it. :beer:
Nope, just plug it in and ride. There is no programming involved with our modules.Homarr said:Step six was the only thing I wondered about when I skimmed over it. That's not anything like this, is it? http://www.v-twinforum.com/forums/showthread.php?t=69427
