1 - 8 of 8 Posts
I recently installed andrews adjustable push rods in my 02 EG. The instructions called for the adjustment to be 3 1/2-4 turns from 0 lash. I adjusted them to 3 1/2 turns but I am still getting some valve lash noise on the rear cylinder. My question is how far would it be safe to go past 4 turns (if any) to see if the valve noise will go away.
The inital adjustment took care of most of the noise in the rear cylinder, and I have no valve noise at all in the front.
Thanks for any help, Wayne
Administrator
Assuming you adjusted them right, going past the recommended adjustment is not going to quiet them down. The adjustment of 3 1/2 turns is to set the cushion at .100". If you have a lifter that is still noisy, something else is wrong.
Andrews adjustable push rods
Thanks for the reply Springer. I'm going to re-adjust them today and if that dosn't help I'll look at something else.
Wayne
Without more info you may have a rod that is lightly touching the inside of the tube. This happens, more info would be helpful lifters, cam, lmr spring and so on. And I agree with spring once you get inthe 125 range you are there,
Andrews push rods
I re-adjusted the push rods today. I still get a slight ticking after the engine gets fully warmed up. Using a mechanics' scope is sounds like it is coming from the rear
exhaust valve. Do you think any damage will occure if the noise don"t get any worse? The engine has a big bore kit but I don't know if the cam and lifters were changed or not.
Administrator
When the bike is warm and ticking, place you finger on the pushrod tubes, one at a time. If one of the pushrods is touching the pushrod tube, you will be able to feel it. Becareful, the tube will be hot.
If you have a cam in it, it is possible that the noise could related a more aggressive cam. Latus Motor Racing makes a spring for the oil bypass valve that might help. You can order it from Baisley, The part number is LMR-002. Do a search on Baisley spring and you will find ton of info on it.
What oil do you use?
We sell a bunch of the lmr springs but if you have a failing lifter not much else you can do but replace it. Now a good tip was made by springer check that out.
Discussion Starter · #8 ·
Andrews adjustable pushrods
Thanks springer. I will try what you sugested. The oil I use is mobil 1 15/50 full syn.
1 - 8 of 8 Posts
