Your warranty is only gonna be good at that dealer anyhow. The "G" is the key, do it!! From what I've read here, you'll be alot happier with the 26g's.
HDWRENCH said:The 26 would work fine, when you have the heads off swap in a 30 thou gasket to help and go ride.
Actualy if you put a SE 204 cam in there your waranty will be in the shitter, only place that will waranty it is the dealer who installed it if they are feeling generous. If they tell you that the 204 is warantied in 48 states they're full of crap, I've been down that road when I did a Stage 2 build on my 05 EG Classic I got the straight scoop from the guy who handled all the waranty work. He said the 204 would be a nice cam but to keep my waranty I had to go with the 203. The only cam you can get waranty on in 48 states is the 203, and then only if it was installed as part of the emmisions legal Stage 2 kit. If something take a crap in that engine and the MoCo can blame it on modifications other than their approved stuff your toast. You have a brand new bike and a choice to make, waranty vs desires. I have the same choice, I wan't to do a build on my 06 Ultra and I'm kind of partial to my waranty right now with only 2k miles on the bike. FWIW when I do the build it won't be with a 204 cam, I'm going with the 26g because I want gear drive so I don't have to worry about the damn tensioners.George C said:The SE would be the easy choice since my warranty would still be intact for all 48 states, but I would sacrifice that, and the extra $500.00 if the 26 cams were a better all around choice with a smoother powerband.
Thanks..
I don't think this is correct.George C said:I think the tensioner issue was solved a year or two ago.
If you ain't gonna ride it, then why swap cams at all?%[email protected]George C said:I'll never have 20K on a bike,
You've hit the nail squarely on the head. There are millions of potential combinations and more than would like to admit it have spent big bucks for a less than satisfactory outcome.George C said:.
I really hate this cam stuff. There are so many recipes, and combos that it makes my head spin. C/R ratio, pipes, powerband area, etc. Constant questions like "should I step up even more and go with the 37G, but then, more compression is needed. It doesn't end...#[email protected] Change one thing and it all changes.
Your dealer probably gets a bigger markup from HD parts as opposed to other aftermarket options.George C said:On a side note, my dealer doesn't particularly like Andrews because he feels the bearing material they use is substandard. This is the first I've heard of anything negative about Andrews. Is there anything I should know, or a different bearing to use?
