1 - 12 of 12 Posts
I ride an 05 Ultra and it seems to leak about 10 pounds of air a month. Is this a common problem? I borrowed a friends air pump to keep a log before returning to the HD Service Dept. We checked all the fittings, also checked the psi in a couple of friends bikes and they were also real low on air. Thanks for any info.
Jim [email protected]
Premium octane member
i could be wrong, but just like tires, they do leak a little bit all the time. It is just that you are dealing with a lot less air in the first place. My 05 leaked out about 3-4 lbs in a winter month....I always check my tires and shocks every week or two. If your leak is 10 lbs in a month i would be testing it.....Check the air line that crosses over the rear fender as i have seen them rub through....Also next time you wash it soap up all the joints really good and look closely at the connections for a couple minutes. It may take a while for one little bubble to sprout.
As said before, the hoses might not be seated completely in the fittings. The best way I found is to simply remove the hose from every fitting and re-insert it into the fittings. To remoce you simply press the red part on the fitting towards the body of the fitting at the same time you pull the hose away from the fitting.
To re-install you just push the hose pack into the red part of the fitting.
0043--Licensed to Doof!
And when you do push them in, feel for a "bump" as they hit the bottom of the seat.
ShakyJake said:
Looks like it is time to dump the air shocks and get the Progressive 440's
Mine leaked like yours do. So, I got the Progressive 440s. Very harsh (for me). Put air shocks back on. Add air once a month or so.
(if you want to try the 440s, I'll sell you some)
greg
I don't know how much air I'm losing EXACTLY, but I know that once a month I put more air into the shocks. They aren't down to zero pressure or anything, but maybe down 5 to 10 lbs between the check intervals.
As TXCHOP said, it's like tires. You got to put air in them all the time. I think it's normal. I ride mine everyday, and expect some air loss. I guess if the shocks are losing air on their own with no pressure being put on them from riding, that would be a different story?
...I couldn't resist adding my -2$en#e- :D
1 - 12 of 12 Posts
