Aftermarket oil pans
1370 Views 4 Replies 3 Participants Last post by  jake24lt
Hey guys any one ever install an aftermarket oil pan on a twin cam Dyna? Is it worth the $$ and possible bike stands problems when lifting bike.
thanks 👍
thanks 👍
Most later twin cam dynas already need spacers on the frame to lift there. I know there is one that adds a quart for baggers, but have no experience with Dyna Aftermarket oil pans.
Yes the Baker pans uses an extra litre.Instead of buying the poly/spacers from Harley on frames,
I use little rubber square mats to lift bike.I hear the extra quart cools the motor.
Oil cooler does good too, IMHO the cost of the oil pan does not warrant the cost unless you are riding full throttle all the time with mods done.
Once the extra quart of oil reaches the same temp as the rest, what have you accomplished? Waste of money, unless you never check the oil. ;)
  • Like
Reactions: 3
