Collecting data under normal driving conditions with a Twinscan ll . Stock sensors in place ( not Twinscan wego sensors. When reading graph the AFR for the rear cylinder is jumping all over the place - spiking up + down from the command afr 13.1 to 14.5. The front cylinder is pretty level. What would be some of the likely causes.
06 Dyna - 113 SE build
One last nag, and probably one of the most important, the pipe, thanks
OH BTW first thing to check, swap the sensors and see if the front is now erratic
The rear 02 sensor plug in is under the seat next to the battery and the front one is inside the plastic guard right above the regulator.
