:hmmm: Has anyone had the "pleasure" ^rolleyez^ of installing a lamp into one of these monsters. The lamp goes in easily enough, but trying to put enough pressure on the front to compress the bezel spring enough to slide the long plastic part into the housing seems impossible. Any words of wisdom... other than don't buy Adjure... please?
Make sure the notches in the spring ring line up with the nubs on the back of the lense/bulb assembly. I have the same light with the long plastic thing and it slides right in with no trouble. :yes:
Man, you are truly blessed!! I had three people check the alignment and we all came to the conclusion all was placed correctly. We finally got it together after a massive collaborative effort. I'm convinced that when the lamp burns out, I'm cutting wires and buying something else.:thanks:
Maybe the lens assembly is the difference. I'm using an E-Code Hella.
