Infidel
Can anyone recommend a source for a small enclosed universal filter to catch the vented oil vapor? 3/8 inch line.
I tried to describe what I wanted to the kid at Napa but he was only able to function with a part number.
Thanks!
Here's one Drag has. All the catalog places have them if you want to order one. If you just want to pick one up locally, don't have a clue.
AIR CLEANER BREATHER FILTER
Prevents impurities from entering the engine when an aftermarket air cleaner and breather kit is mounted
Muffles crankcase venting noise
Measures 1 1/2" L x 2" in diameter; 3/8" inlet on each end
DS-289073 Dual inlet filter $ 12.95
K&N also has a bunch of them http://www.knfilters.com/vent.htm
Thanks!
Don't have an answer for you, but are you sure you need one?
I run braided tubes about 18" with no problem. Fairly hot 95" build.
