Need a little help. My speedometer on my 99 superglide stopped working. When I enter diagnostic mode, the only error that I see is D02-Set. The rest (D01, and D03-D09) show CLR. After tracing the wires from the speedometer, I see that the one in question goes directly from the speedo into the transmission. There is a plug in the middle of that wire under the seat, which appears to be ok. Initial visual inspection of the wire appears ok, however I didn't remove the entire thing, so there could be a short somewhere allong the line, but very doubtful. The bike only has 8,000 miles.
The needle on the speedo doesn't work, nor does the odometer, however the light works fine. I assume the problem is with either the speedo itself, or the pickup unit.
Any ideas?
Any ideas?
