Okay so long story short my 88 fxrs progressives were 18 and change and the Dual disk front end I put on from a supposed 97 Dyna are 21 and change. The forks themselves on the 97 front end we’re 1.5 inches taller than my stock fxrs front end here’s a pic for reference .
266662
I was wondering if anyone here had info as to if the spring set that came with the 97 was a stock length for that year Dyna? Looking for progressives or race techs for it but the part numbers from progressive are the same for both so I’m stumped.
1982 FXR Shovelhead
progressive might have used a longer spacer on the newer forks
  • Like
Reactions: casement
Fork tube length and rebound rod length determine the full extended length. You have one or a combination of the two; or someone did not put the topout spring back in the longer set. Spring length does not determine the extended length.
Vitally important to understand what Lloyd has stated... re-read and understand...
also note... H-D is Famous for varying fork tube length...which has Zero to do with Damper tube length but plenty to do with Spring [or Spacer] length... Whenever you see the specs for Rake, Changed in H-D literature, in a common Chassis ie Any 4-speed [pre-1985] any FXR[any Letter here] Rigid mounted Sportster ...4 speed and also 5-speed...
the MoCo has Changed the fork tube Length... in order to change [slightly] the effective Rake Angle..
The Progressive kits come with PVC pipe (the classic shim method) and there's no reason you can't shim yours to whatever pleases you. I would prefer the Dyna front end for the extra ground clearance since my local roads svck and the less easy it is to scrape peg mounts and/or pipes the better. It would be bizarre for Progressive to use a longer spacer since the difference without the extra spacer length would waste that much travel. There's no reason for the springs to be different. I have their springs in my '88 and '94 and like them. When I went to an FXRT front end on my '94 FXLR I reused my Progressives and cut longer spacers.
