what size risers do the 1200c come with? i was thinking a 6 inch riser but was wondering if the cable lengths from a 1200c would work or still be too short. i have the reg pull back bars now, so just trying to figure this all out
The stock XLCustom risers are 5.25 to the center of the bar. Distance wise, the rise/pullback of you bars is close to the drag bars & risers, one difference may be the angle of the brake fittings at the bars. Try your cables.
I have 7" rise and 8" pullback Tee Bars and the stock cables are fine. If I had gone any higher would have needed to change the clutch cable. I had flat drag bars on and found they would hit my fatbob tanks or the dash. So I went with the tee bars. I also find them more comfartable.
Bob
