I have a 2005 Dyna with V&H Big Radius exhaust, stage 1 AN Big sucker air kit and a revtech DFO. After reading alot of your information I have come up with two build kits (listed below) and I would like to get some input from others as to which one would be the best option with stock heads.
Kit 1
Kit includes 95" Harley Davidson Cylinders, Keith Black Pistons with rings and piston pins (10.0:1 compression ratio), Harley Big Bore head gaskets (part # 16787-99), and Harley Davidson complete top-end gasket set.
(Andrews TW31s Great cam for motors with 95 inches and 9.8 to 10.2 CR. Lower TDC lift for easy installation. Similar to TW37 with different timing. (2000-5600 RPM). )
Kit2
Kit includes 95" Harley Cylinders, Screamin' Eagle piston kit part #22851-99A, Harley Big Bore 95" head gaskets part #16787-99, and Harley Davidson complete top-end gasket set part #17052-99B. The piston kit includes rings, piston pins and circlips. This kit has all Genuine Harley Davidson parts!
Andrews TW37b
Kit 1
Kit2
Andrews TW37b
