When doing a 95" conversion,what is the prefered piston...the standard flat top or the high compression?And why?Also what about cams,which one?(This is going to be my '01 FLHTC winter project)
What pipes are you running? Are you Carbed or FI?FLHP said:Flat top pistons, SE Performance Heads, and SE 257 cams. 102 hp, 104 tq,
FLHP,FLHP said:Flat top pistons, SE Performance Heads, and SE 257 cams. 102 hp, 104 tq, and extremely reliable with mileage just over 40. Can't say why I went one way over the other than I had seen some similar set ups, and went with what seemed to work every time.
