2004 FXDX
95 JUGS
SE HTCC PORTED HEADS
HTCC PISTONS
SE 257 CAM
MIKUNI 45
3.37 GEARING
SE ADJ PUSHRODS
SE TAPPETS
SE ROCKER SUPPORTS
BAISLEY SPRING
Some time ago I posted a question about clatter in front jug that increased as the motor warmed up. Installed Baisley spring, no help (for the clatter tho I am sure it helped oil pressure>)
Finally got a chance to tear it down last nite. The rocker arms are in fact hitting the boxes, we did not machine them enough. Will do so this weekend. Will update you because of success.
the clatter was pretty irritating plus the rear rocker box was leaking oil - I am glad we found the offending item. I will keep you posted.
thanks
95 JUGS
HTCC PISTONS
SE 257 CAM
MIKUNI 45
3.37 GEARING
SE ADJ PUSHRODS
SE TAPPETS
SE ROCKER SUPPORTS
BAISLEY SPRING
thanks
