Tman 590G, Andrews 67G, S&S 585G. None of these will have the manners down low, due to increased overlap, of the 203s but will offer 10+ hp increase, assuming good engine health and proper tune and pipe.
Well, this is where I am now. Among the Tman 590G, Andrews 67G, and the S&S 585G, I am leaning toward the Andrews 67G camshaft. I did some ciphering, and I might be giving up a little power to the other two cams, but I'm not sure how much or where in the powerband.
What I might be gaining from the Andrews with a smaller .570 lift but longer duration and overlap, should be easier starting, and a quieter, more reliable valve train. My cold cranking compression should drop from 205 to maybe 191 psi, which is probably a good thing.
Also, although other cams with higher lift may not cause coil bind in the SE heads, maybe there could be issues with accelerated spring fatigue, or insufficient spring pressure. That subject has not been brought up yet in this thread.
And, the Andrews 67 is almost identical to the SE 257, which was one of the top performance cams in the 2001 parts and accessories catalog. Someone at the factory must have thought this cam was a good match for their top SE cylinders, pistons, and heads from that era, which is what I already have. But my current SE 203 cam was the only performance cam available in the 2000 parts and accessories catalog, which could explain why I was never offered the SE 257 option when my dealer built my engine in 2000.
So, Andrews 67G is what I'm thinking, is my thinking correct?
(Edit: But I still like the S&S 585 and the Tman 590, so still deciding, at least I've narrowed it down from 3000 cams to 3)
