1 - 2 of 2 Posts
What do people think about this build on a bagger? I was going to go with a Scotsman, or Deweys 37g build, but for the price diffrence this might be good enough. I ride 2up 10% at the most and like to get on it when I can.
95" cylinders
SE 211 cams
.030 cometic
SE Hi Comp Forged pistons
stock heads
I also thought about this bulid with SE performance heads and flat tops?
I soon will make a decision as have I started to disassemble my bike.
As always thanks for the replys
Welcome to the board
Ok your Se build Even with the piston you choose you do not have enough compression. That se up will yeild 9.6 that 211 works better at 10.1+ even at 10.1 it is a late building cam not my first choice for a bagger. I have swapped plenty out for a woods tw5 as the riders all wanted more bottom end and that was with 10.5 compression and the HTTC heads.
There are several ways to get power without h/c not that it is a bad thing. 9.6 comp ratio and the 204 would be a better choice if you are stuck on SE parts.
If you take some time to search builds here you will find plenty of combos , such as what you are looking for.
95 kits
98 kits
All have a use some offer more than others.
1 - 2 of 2 Posts
