1 - 12 of 12 Posts
CBA Member
I have a 02 E-glide. 26g cam with a power commander. I want to
know if I should go with the harley Hi compression pistons or should
I stay with the flat top. I have the stock heads and will have them
cleaned up a littel befor putting them back on.
Any suggestions as to what pistons would be best.
I do alot of 2 up but would like to have a little more power
without the ping.
Thanks for the help..
Knower of Stuff
The 26G does not like Compression too much above 9.5:1. Go with flat tops and if you want a little more compression, cc the heads and have them milled to get what you want. A stock 95 with flat top pistons is 9.3:1 with a .040 and almost 9.5:1 with a .030 gasket assuming 85cc heads and 0 deck height.
I agree , no reason for hi comp pistons with that cam , and the flat tops will go up to 10.2 if you decided to change cams and headwork. I'm running just over 10:1 with them , I am running a 31G and SE heads though.
Infidel
Check with a local indie shop and see what machine shop they use. Any decent machine shop should be able to do it...make sure they're using torque plates though...should run around $50 a hole give or take. I agree with drdrvon, for your build the SE's will work great and they're a bargain...less than $100 at the discount houses! Good luck!
No need to go forged unless you are going to the drags, check Zanotti's for the SE case p/n #22851-99a
CBA Member
Discussion Starter · #9 ·
Thanks for the replys people. I will check on the parts and see what I can
find. As to a machine shop around here:huh: I dont think I would let them
bore a lawn mower. If any one knows of a place in Wilmington NC or Myrtle
Beach area please let me know.
Again thanks:
1 - 12 of 12 Posts
