I posted them last summer but my photo host must have dropped the pics cuz the graphs are no longer visible. The first runs, have the choppy lines (which I traced with highlighter) because of a problem with the dyno set to read every 360*. The tuner then put both leads on one plug wire and had it read every 720* and the traces were fine. The rest of my build is pretty well covered in my signature line.
Constructive comments appreciated. I think there is more power in there...and that I lost some of it running too much advance on the ignition. DTT recommends no more than 30* advance at 5000rpm and up...and at the time of this tuning, I was running 35*. I have since rectified that, and I can't wait to get it back on a dyno this spring.
FYI: The first graph is a best run WITHOUT the air cleaner on. Second graph has the air cleaner on and shows the AFR. Third graph is the before and after comparisons. The only real change made to between runs was to richen up the top end with a bump of the main jet from 205-220.
