1 - 17 of 17 Posts
I'm assemblying my jugs and heads as I write this. The gasket is the .030 Cometic head gasket. The Cometic install instructions say that "there should be no over hang of the gasket in the bore..." I've got .020-.025 hanging over the piston all the way around. Is this normal? Piston @TDC never makes it to the gasket, I checked. Also installed the head bolts to "center the gasket.
I'm worried that I may not have the right gasket?
Need urgent reply.
Thanks.
DLR
95" pistons installed in the 95" jugs perfectly.. I measured the gasket diameter, and what do ya know... Cometic made a boo boo... Packed 88" gaskets in a 95" part numbered packet... Thanks for the help. I was off wrenching on other things while the response came back...
Damn, held for (3) things now....7/16, 1/2 inch dog bones and the RIGHT head gaskets...LOL.. Oh well. It's a long winter and I'm ahead of schedule anyhow..Don't want to run out of things to do before we ride again!
Thanks,
DLR
ovanay elinquentday
pa-glazier said:
This is how you use the dog bone wrench to tighten the back rocker cover bolt. Up side down torque wrench and dogbone at a 90° to the torque wrench.
Where did you find the dogbone? I'm looking for the right ones to torque my motor back together. Thanks.
Just the facts ma'am
I second this request. Tear down of my build is complete and starting the assembly process. I'd like to purchase before actually needing the tool.
Thanks in advance,
Joe
95" kit supplied by hdwrench
Andrews 26g cams
2002 FLSTF
Delinquent
Need urgent reply.
Thanks.
DLR
FYI,
Just in case this doesn't come with your gasket.
Look at page 36 for the sequence, steps and values.
http://www.cometic.com/catalogs/HDCat04.pdf
I can tell you that I didn't cut off the brass rivet and they interfer with the pushrod tubes just enough to be annoying.
vafatboy said:
FYI,
The brass rivet location has changed away from the pushrod tube. Must be an older production run, maybe 1 year old or more.
Delinquent
That's good news, just a "little" engineering oversight. Got mine around January 2005. Don't know when it was made.
Discussion Starter · #12 ·
Yeah,
My included directions don't discuss the removal of the brass o-ring, but I'll check it anyhow. Oh, and on the dogbones, thanks for the access tip, (upside down @90 degs.). I knew there was a way. Saved me some time. I'm pretty sure we're going to have to go to the Snap On Man...He quoted me $127 / 5 piece chrome and $117 / 6 piece black oxide. Can't find'em anywhere else...
Thanks again,
DLR
Nice to ride again :-)
Dog Bones
Hey just run down to Harbor Freight buy 2 cheap 3/8" wrenches, the two socket sizes, whack the box end off the wrench, weld a socket on each one and woolahh two very cheap dog bones for using a 3/8" torque wrench.
This was taught, and shown to me by Dynatherapy, and is what we will use when we tear into it this time to R&R the exploded rocker support plate.
1 - 17 of 17 Posts
