My block got a crack was looking purchase a replacement evo but need to know is there any big year differences I should be worried about?
why dont you just replace the cases,,, if they arent available from the dealer,,, S&S sells cases... they sometimes require minor fitting
.. the last set of cases i did,, needed the end play on the left set,, and a different pinion bearing.. the pinion beaeing was too tight and the end play was a little loose.. everything else just went together fine... but i must admit,, i have done alot of work requiring splitting cases and different cases..
now is the perfect time to freshen it up with a little more power,,,
if you look around new cases can be had for under $1k.. and are far superior to harley cases.
