While trying to adjust my knob to stop sliding in while idling, the plastic threads disentigrated and now I need to replace. I see where it enters the carb (nut) but do not see how it attaches internally. It looks like I have to remove the gas tank to get to it as well. The Clymer book does not go into enough detail.
After I loosen the nut where it enters the card, how does it attach? Thanks
You don't have to remove the tank but probably will have to remove the carb. Just loosen the plastic nut where the 90 degree bend takes the cable into the carb. The cable end in the carb will just slide right out. Be sure and get the rubber boot positioned properly when re-installing.
Don't over-tighten the 9/16 nut on the back of the enrichener knob either or you'll wind up getting another one.
I have never cared for the Clymer manuals whether I was working on a car or bike. I work on a friend's Sportster and he has a Clymer manual. I hate having to use that book. Do yourself a favor and get a HD factory service manual. It's well worth the money.
