1 - 16 of 16 Posts
1984 H-D FXRDG
Looking for a used 1984 FXRDG Carburetor, for stock 80 ci, 1340 cc engine (OEM, S&S, or CV), bolt-on, no mods required.
1984 H-D FXRDG
Did you find the 38mm keihin butterfly carb you thought you had? Where are u located, and how much are you asking for it?
1984 H-D FXRDG
Discussion Starter #10
OK, If that one doesn't work out, I found the one I have.
I may need your help...how much are you asking for yours, and can u send me some pics (all angles) and details of what it came off of (year, make, model) so I can be sure it'll fit? Where are u located?
It was on my 84 FXRS when I got it. I took it off and an switched it over to a CV 40.
Its a pretty standard K38. Dual throttle cable, choke cable, fuel inlet pointed down, VOES port.
Its up jetted a little from oem.
I'm thinking bout a $100 to your door, lower 48.
1984 H-D FXRDG
Discussion Starter #13
Thank you! I'll consider and let you know...
Looks identical to mine. When you say "upjetted", what do you mean? Will it run on a stock '84 FXRDG with 80 ci motor? Will you take $50 + shipping?
From the factory, the carbs were jetted lean to appease the EPA. Up jetting just means a larger jets were installed. Make them run better. Yes it will run on a stock 1984 80 inch motor.
Where do you live? Zip code is what I need.
1 - 16 of 16 Posts
