Ok I can get the tranny to still spin freely just not shift.
Yea that’s the diff between pros and shade tree mechanics like me. The pros know what doesn’t look right while it could be starring me in the face hahaI hear ya but something aint right, would inspect is my point.
I hear ya Arc and agree 100. There’s a few guys on here that have forgotten more than I know and they’re life saversarcangei thank you,,, I'm not that type,, 8f we were in the same shop,,, and one 9f the mechanics were having the issue mentioned here,,, I would just smile and walk away... I am here to help, though,,, I rarely have a question about harleys or anything on wheels really,,, my background includes enough certificate to paper a wall,,, I see that as fake BS thar is unfortunately required to continue making a living in this profession..
jake,, I wouldn't do that to you,,, but I'm glad you thought of me,,, perhaps,, lower in this post you may find a solution to the issue... if that fails,,, Baker 6 speed OD shift components fit right in,,, but cost more than the gearset did from ultima...
then I would tell him,,, the shift drum has variable thickness shims that can possibly solve this problem,,, available through harley and the aftermarket... there is a measurement spec in any of the 5 speed manuals you can lay hand on,,, that tells the measuring spec and the procedure...
I do remember that the measurement is taken off the door side of the case ,, sans the door and gasket,, to the center of the middle shift drum groove in 3rd gear... I just dont recall the dimension.. 2.013" from the edge of the case to the center of the .idle groove in the drum in 3rd gear iirc,,,
this can be accomplished without removing the door,,, with a couple of the correct mics,, and some calculations...
this may fix the shift drum bind,,,, I guarantee it is not the harley case causing this issue..
I've had mixed success with ultima transmissions with the same or similar problems....
my big gripes with ultima is their inferior materials (yeah they use 8620,, with one major difference,, they remelt scrap and cast most of the gears and shafts,, rather than machine from bar and flat stock,, like Baker does).and loose tolerances ,, leading to shifting issues...
therm may have some insight here as well...
