I did the Feuling HP+ camchest kit w/525 cams in my 2004 FLHTI TC88. I replaced my true duals with V&H 2 into 1 propipe at the same time because my local speed shop owner said I'd give up about 10% of the performance if I kept the duals. I run a simple K&N breather on it. After those changes the bike dyno'd 90/91. You could feel the increased torque big time.
Very pleased with the change but after a couple thousand miles I started getting pretty bad leak down from the piston rings so I had to do the top end. Bored it for 95" KB pistons and rings, valve job with new springs and light decking of heads and thinner head gasket. New Dyno run 92/100. Totally different bike in terms of performance. Dyno results below so you can see what kind of torque band the 525 cams give you. Top is just the cams, bottom is after top end rebuild. HP comes on a little late but as you can see she pulls pretty strong where I want it on a bagger 3-5k rpm.
I talked to the tech guys at feuling a few times during the process and they give excellent support. In retrospect I wish I'd done the top end when I did the camchest. Like you I was "just replacing the crappy tensioners and thought why not do cams?" but I could've saved the $500 on the second dyno if I'd done it all from the start. I did all the wrenching myself and had the cylinder and head work done at a reputable local machine shop.
