1 - 2 of 2 Posts
· Registered
:) Have an Old shovel dresser with an enclosed rear drive chain. problem is the tranny oil leaks past the mainshaft seal when the bike sits on the kickstand for long pe riods. This overfills the chain housing causing it to leak. I put a new seal last winter because of this problem and was fine for a couple thousand miles . I have heard that the depth of the seal is critical . I made my own seal driver. Do I need the special driver ? Any one have any thoughts on gettin a good seal . Big hassle to take this all apart every year. TIA MULE...LL.ORG
· Registered
Hiya Mule. Keep an ey on your thread as it will probably be moved to the Tech side. You will get lot's of help there. Watch for posts from The Hippo. He is a great tech.
1 - 2 of 2 Posts
