1 - 2 of 2 Posts
You don't say?
Finally got to ride the Low Rider after the primary gearing swap. Overall I'm quite happy with the change. She runs at 2300 RPM in 3rd @ 30, 4th @ 40 and 5th @ 50, which is just perfect. At 65 in 5th she'll quickly run to 80-85 with just a twist of the throttle. It woke up my build (95", 10.5:1 DM 590G cams, 45mm Mikuni), but it's not earth shattering. I can say this, though. She'll pull the front tire off the ground in 2nd @ 3K when you grab a handful. And the tire will break loose by doing the same in 1st!
I had a 3.37 on my last ride , they are a blast , I do like the 3.15 better on the freeway .
1 - 2 of 2 Posts
