1 - 12 of 12 Posts
Am having dealer install SE performance heads tomorrow am currently running 203 cams. One mechanic suggests 211's, the Service MGR wants to put 258's but from all I can read the 203's have the best low to mid torque and performance. Need Advice Quick. thanks MIKE
I'm sure you'll get replies from people a lot more knowledgable than I am, but I am sure no one will recommend you use the se heads with the 203s. I think the 211s are a pretty good cam with the se heads. From the specs, it looks like the 211s would give you better low / middle torque than the 258s. The se catalogue says the 258s are for use in high compression applications, with peak power in the higher rpm ranges. I'd go with the 211s.
Knower of Stuff
What are you looking for? What is your riding style?
2 up grunt, solo rocket, street racer. The package needs to match your riding style or you will not be happy.
Also, did you install the BB kit and what pistons are you using. All this determines the corect cam for max performance.
I just left dealer I am doing the SE performance heads. Already have the 95" with se203's but decided to change to the 211's while the bike is apart. Thanks for all you help I will post results Mike
Discussion Starter · #6 ·
rsmari I did not change pistons, but I did go to SE Performance heads with the 211's. Should get bike back late today or tomorrow and I will post results. Thanks mike
Discussion Starter · #7 ·
Just picked up bike this afternoon, only rode about 15 miles and am very satisfied with the new mods. Can anyone tell me what compression and HP/TQ I am running now(I know you will only be giving a close guess). 2004 Wide Glide. EFI;95"BB;SE Performance Heads(with HD Headgaskets);SE211 cams;Stage II flash. I know it will not be exact but I know some of you guru's can come close. Thanks for all help again. Mike
DYNO RUN!!!:yes:
Discussion Starter · #9 ·
deuce04 said:
DYNO RUN!!!:yes:
That is exactly what I intend to do. But there is not anyone close to me. I thought maybe someone could give me a good educated guess for now. Thanks for advise. Mike
Another Old Fart
Mike I have stock heads but with my 211's and SE Slip On I dynoed at
83hp and 99 tq. Hope this helps....... Mike...........
211's
I've got a 95" with stock heads. Upgraded to 211's and love them. Dyno'd at 90 HP/95 lbs. Tq. Also have Rhienhart true duels. Bike has a lot more mid to high range pull.
1 - 12 of 12 Posts
