1 - 9 of 9 Posts
I've had my transmission replaced within 1k miles.
I didn't heear thhis noise prior to getting the transmission replaced.
it happens in neutral with clutch out, pull clutch in and put in 1st gear no noise.
If I pull clutch in and roll IN GEAR I have this noise. if I shift the gear from 3rd to 2nd to 1st, WHILE ROLLING the noise gets louder the lower the gear I go.
dealer says it's backlash from the new transmission with the gears and it should break in over time and miles. has anyone else experienced this?
https://www.youtube.com/watch?v=d_lQ...ature=youtu.be
here's a youtube video of the whine in motion
I appreciate any help given.
All bearings were replaced according to my Work Order, including the inner primary bearing
Attached work orders below
the IPB was replaced by another dealer
What was the problem before replacement? Was trans replaced or repaired, looks likes repair by parts listing.
that is a repair/rebuild,, not a replaced transmission...
manual transmissions sometimes make whine noises,,, its just the way all those spinning gears are...it does not mean there is anything wrong,,
Discussion Starter #6
I'm sorry? I don't understand how full shaft/gear replacements isn't considered a replaced transmission? or are you saying this simply because the case wasn't replaced?
There's no mention of the counter shaft or gear replacement. You got 1/2 a new trans.
Discussion Starter #9
also referencing the parts list, you can see 35246-10b includes both main shaft and countershaft, it's the entire unit.
265918
1 - 9 of 9 Posts
