There are times when the bike shuts down after turning while throttling up. E I P appears in window. Will turn all switches off and bike immediately restarts -- Any ideas?
turning in both directions?
tip-over switch
what window?
how many switches you got?
do you have to turn them back on?
pinched wire, any work done recently?
Do you restart with the wheel straight ahead? You have a wire in the faring when the wheel is turned stretches tight and has rubbed the insulation until the wire is touching metal and causing a short. Straighten the wheel for restart and the wire has loosened. I had the same trouble with my radio which was the warning shot as the battery would drain while riding. I thought about carrying a battery jumper like sold at Walmart.
