Hello, would you happen to know if a gas tank for a 2010 Electra glide (or touring) could be modified to fit a 1992 Electra glide (or touring) frame. I tried to locate pictures of each frame but have not had any luck. Thanks.
2010 is a fuel injected tank 1992 is carb so there is no provision for a fuel valve. It could be jury rigged but the correct answer is NO.
With a welder and a torch anything is possible.
Yes it is as I and some others on here could Tig weld a gas valve fitting into a fuel injection tank to make it usable for a carbureted bike, but us that could do it would not have to ask. The fact that the op asked tells me he can't and it is out of his scope of expertise. If you wanted to do it you could even without a welder but it's not a great idea.
Discussion Starter #6
thank you
