I have a 2009 Harley Davidson Fatboy I am trying to remove the stator but I am having a problem getting the I guess you would call it the bellhousing for the stator I'm having a problem getting it out yes I know it is magnetized but when I pull it it only goes so far it actually gets caught on the primary if anybody can you give me some advice that would be wonderful cuz I really do not want to pull the inner primary I don't even know if I can do that I am totally confused at this point
Pull the inner primary, then bend a coat hanger so it has little hooks on each end. Put a hook into each of the little holes in the rotor, and use the coat hanger to yank it off.
Book says to use new primary bolts. But you can get new seal rings from J&P, and then just clean the locking material from the bolts and holes. Then reuse the bolts with blue loctite.
