just got the dyno sheet from the local harley shop on my new ride.
got what i was expecting as far as horsepower, but the torque numbers are lacking, and expecially sluggish in the lower rpms???????? anybody else have this setup? what kind of numbers are you getting? is this all i should be expecting? the setup is on a 2006 electra glide, fuel injected... the harley big bore stage ll kit... 95 inch with 203 cams... loaded the stage ll ecm, and the dealership tweaked it a little to get the right air to fuel mix.
no sure how to post a copy of my dyno sheet, but some quick numbers....
max hp 81.94 max torque 88.73, the dyno sheet harley advertises in the screamin eagle catologue shows the horsepower right around 82 but the torque around 97???? i was hoping to get close to that torque number??
am i dreaming? the torque curve is way off too.. in the catalogue at 3500 rpm the torque jumps up to 97, where on my dyno sheet at 3500 i am only at 80?? any information or input will be greatly appreciated, thanks in advance.
