1 - 8 of 8 Posts
Hi I am stumped I just replaced my stator and rotor because the bolt loosened and destroyed the magnet but after starting with all new parts I'm only get 4 volts from the stator does anyone have any idea why it's not building voltage still?
Check the output at 2000 and 3009 rpm at the stator plug,,, voltage should increase appx 18-20 volts with every 1000 rpm increase,,, 40 at 2000, 60 at 3000, and so on,, I never exceed 3000 rpm, while checking output..
Discussion Starter · #7 ·
I solved the issue I had the volt meter on the wrong setting hahaha
1 - 8 of 8 Posts
