I've acquired one of these bikes that has been long garaged and am attempting a restoration. It has a Screamin' Eagle air cleaner assembly. Is it likely that this would have been an OEM component for this bike? If so, would the injectors installed be of a larger size than "stock"? I don't have a build sheet... not sure if one can be acquired. I suspect my front injector is faulty. Thanks for any input!
No to both of your questions.
concur with turboprop... you are embarking on a long, expensive road,, with many questions and many answers you wont understand right off,,, its the harley way.. the factory never supplies as srock what they can charge you for after the purchase.. enjoy
Thanks to you both for the replies. I'm the third owner, so one of the earlier owners must have installed the high flow air cleaner/breather. I believe you regarding the path to ultimate success. I'm trying to do as much of the work as possible...and learn what I can during the process.
