I have a 2002 Fatboy I'm upgrading the brakes on. I figured I'd post this here if anyone has already done it and can lend some advice. I have a set of calipers from a 2019 CVO Road Glide. I am replacing the current 11.5" rotors with 11.8" rotors, the 9/16" master cylinders with 11/16" master cylinders, and throwing some stainless braided brake lines on it. The front brake caliper and rotor look like they're going to bolt right on and work with no problems. The rear caliper and bracket is where I have a concern. The stock bracket is wider than the CVO bracket where the axle passes through it. By what looks like about 1/4". Easy answer is get a 1/4" spacer, throw it in there, and be done with it. That's where I have questions. Is it as easy as throwing 1/4" spacer in there? Or, do I need 2 1/8" spacers so there's one on each side of the bracket? Or, do I need something else? I'll be making a youtube video of the install when I do it to hopefully help someone else in the future.
