Looking for advice. I have an 01 FXSTI that has Vance and Hines Long Shots. I want to remove the baffles for better sound. What should I be concerned with if I remove them,other than the local noise ordinance? Will my fuel injection still work properly or will the bike need adjusted?
Thanks,
Mike
Premium octane member
You will have a dip on the low end torque. It shouldn't be that hard to take them out, maybe a few minutes. Try and see how you like. Keep an eye on the plugs to make sure its ruinning o.k. I have a couple friends that did it and were not happy at all with the baffles out....watch out with FI and drag pipes...
Checkout Thunder Monster Baffles from www.bigcitythunder.com.
You pull your baffles out and install theirs. Increases sound big time, and is supposed to keep it so you dont lose much low end. Also supposed to increase mid range power. I have em. Putting them in this weekend. Only $80. Give them a call, they are very helpful.
