New to this, so please bare with me.
I have a bike, needs new frame. The engine runs great just wondering what frame i can mount the engine on without major modifications. Does it have to be a dyna super glide ? and what years of frames are compatible.
Thanks for any help
IIRC, 1999 through 2005 dynas will work.
Any dyna 99- 05 would be same since they are all twin cams right. After 05 they went to the 96” motor and 6 speed but I don’t remember hearing any frame changes till 08.
If you’re reusing everything but the frame then you need to keep with a dyna in those years or your harness won’t fit right etc. lots of variables in here.
99-05 Dyna and 99-06 touring engines were all the same.The 06 Dyna is a bastard year.It is configured like the 07 and later 96 inch touring engines but is 88 inches instead.Pretty sure some ,if not all primaries, are different between touring and different Dyna models of the early Twin Cam years.
