1 - 2 of 2 Posts
I would like some opinions on modifications . I have installed Screaming Eagle slip-ons w/o baffles, but am not happy with sound. I want a deeper sound and re-jet. Also would like a lope in engine idle. Any suggestions for this novice?
So you want to spend some $$$. How much?
You could put in some big cams, but without raising the CR you will kill your low end power. At say 10:1 the TW-50 sound pretty good for more you need better valve springs.
The S/E211's are said to need springs but Ive seen guys go without them.
Oh course this leads you into the "sould I do headwork" ????
Now for your pipes , to me I like V&H long shots for sound, the shortshots are pretty good to. The Pro pipe has good sound but way up there on power. Alot of good pipes out there you need to look & listen for your self.
You will get a different answer for every post wait -n- see.
1 - 2 of 2 Posts
