1 - 2 of 2 Posts
I had to put in a new battery since the original was defective. While I did this I was working on a turn signal problem that led down to the the turn module needing replaced.
After that I went to check the charging system to make sure all was ok and its not. I followed the book and checked ground and its good. When I disconnected the connector at the regulater it was full of oil. Dripping out quite a bit. I stopped there and thought I better come in here and ask WTF... Any leads to why? And where is this oil coming from?
the oil is probably from the filter... every oil change usually dumps a mess down the regulator and associated wiring.
Get some electrical contact cleaner and spray it down good.
1 - 2 of 2 Posts
