The new 2006 Softail’s have a standard 200 series tire on the back. HD accomplished this with the same swing arm by changing the rear pulley and belt to a 1” width with thicker spacing between pulley/hub. The swing arm is the same as the older models. I have a colleague that’s making that mod to his 2004 Softail Std.
Can anyone tell me if the same mod is feasible for the Dyna frame/swing arm assy. Meaning changing out the pulley to a 2006 version with the narrower drive belt. A 200-series tire would require a wider fender though, and that may hinder such a mod.
Would the frame allow the change-out to a wider fender?
