Going to True Duals appears to be a good option if one wants to eliminate the heat generated by the OEM cross-over pipe. The rear pipe on the 2-1 systems is not in the same place as the OEM cross-over, but I was wondering if there was much heat felt from this pipe? If I had to guess I would think that the heat issue with a 2-1 system would be less than the OEM but more than True Dual. I'd like to hear from those who are using these systems. Thanks.
FOG
Kam,
I believe jlelliott was referring to the heat problem generated with the factory crossover header pipes on baggers. Fatboys don't, afaik, use that system.
T113
your ad could be here
My experience.....
I went from the Factory crossover to the Thunderheader 2:1 - vastly more comfortable on an all-day ride. Most 2:1 exhausts effectively sweep the rear cylinder's exhaust low and away from the rider's thigh, and this makes a difference in the saddle.
I get less heat from my trapp 2:1 then when it was stock with slip ons. 04 flhtc. An added benifit is when I went with the 2:1 my oil temp dropped according to my oil temp gauge.
Discussion Starter · #6 ·
Thanks......
for the replies. The comment about lower oil temp was interesting. Think I will try the True Duals first and if not happy then move to 2:1.
J
