I got rid of the hoopy way too long braided clutch cable someone had on this bike to fit their buckhorns, i have installed the OE style clutch cable and routed it too my liking. Boy does it feel better....that braided one was stiff! I also put the factory SP bars back on & got new throttle cables from FXR division. The manual shows the throttle cables staying on the inside of the bars, then going down through a loop that is held by the front gas tank bolt, then under the tank through the tang.
I have seen quite a few pics of SP's that had the throttle cables ran under the bars, out front to the right of the headlight, down through the fork then back through a loop that is bolted further down on the neck. The factory way seems to work fine but any reason for the change? Which is right?
